Forums >> Revit Building >> Technical Support >> How to make a flexible radius parameter for pipe thicknesses?
Tue, Nov 4, 2008 at 12:55:01 PM | How to make a flexible radius parameter for pipe thicknesses?
jmqrsq
5 Stars: 3 Votes
Am I missing something? I start with a Generic Model and cannot get it to work. I have tried to use one and two radial dimensions and then assign a label or parameter to them which works fine. But the minute you try to flex the parameters it says "constraints not satisfied" and makes me cancel or delete the parameters.....
Revit 2009
Windows XP Pro
Tue, Nov 4, 2008 at 1:10:35 PM | How to make a flexible radius parameter for pipe thicknesses?
tim123
4 Stars: 19 Votes
Remove all the dimensions.  Give it a dimension showing the radius while still in edit mode and give it a label, such as radius.  The pipe should then flex correctly.  Your problem seems to be that you have given it a dimension that is restraining it and then you're trying to give it a label dimension.
Tue, Nov 4, 2008 at 1:58:14 PM | How to make a flexible radius parameter for pipe thicknesses?
jmqrsq
5 Stars: 3 Votes
thanks. that appears to have been the problem.
Wed, Sep 16, 2009 at 6:08:06 PM | How to make a flexible radius parameter for pipe thicknesses?
ksmith
I struggled for quite sometime trying to get my radius to flex until I saw this post.
Many thanks
Kirk
USING REVIT 2011--- This old builder is determined to Learn Revit no matter what it takes.
Wed, Feb 8, 2012 at 12:55:42 AM | How to make a flexible radius parameter for pipe thicknesses?
goovirus
goovirus Avatar
5 Stars: 3 Votes
This is a great tips, been struggling trying to figure this out, thank ou very much!!
problem with connecting flexible pipe to lighting with gland
Fri, Jul 31, 2015 at 12:55:02 PM
Flexible Profile Problem
Tue, Sep 27, 2011 at 3:34:07 PM
Pipe Accessories and Pipe Type parameter
Tue, Dec 27, 2011 at 11:25:39 AM
Need help with Family Content
Mon, Apr 28, 2008 at 8:09:10 AM
Revit2013 - 'Pipe Size' Parameter Can't Be Used
Mon, Jun 10, 2013 at 2:25:34 PM
Page generation time: 0.6307
