Forums >> Revit Building >> Technical Support >> help with 3ds mesh into a wall in revit
Tue, Nov 4, 2008 at 9:47:26 AM | help with 3ds mesh into a wall in revit
office5280
Hey everyone,
I have a mest that i can create pretty easily in 3ds max which i can then import using the .dwg format into revit and can of course create a wall from face from the mass. but it always comes through looking segmented and messy. unfortunately there is no way for to create the mass from the modeling tools in revit. so if anyone has any ideas about how to take this 3ds form and put it in as smooth walls in revit i'd love to hear it. I've attached the .dwg file below and some screen shots.
 thanks.
Tue, Nov 4, 2008 at 10:49:22 AM | help with 3ds mesh into a wall in revit
4 Stars: 205 Votes
Try to create/export in ACIS solid, not mesh, the problem with mesh is that....
Thu, Feb 12, 2009 at 11:52:56 AM | help with 3ds mesh into a wall in revit
office5280
can you do this in 3ds max? if not what program? i'm kinda looking for some steps
Thu, Feb 12, 2009 at 12:33:09 PM | help with 3ds mesh into a wall in revit
4 Stars: 205 Votes
You can do that in Max, Rhino, solidwork, sketchup..... whatever
Also check this model made for Beijing Stadium....
Thu, Feb 12, 2009 at 3:52:32 PM | help with 3ds mesh into a wall in revit
erland73
erland73 Avatar
4.5 Stars: 85 Votes
You forgot to put the link or the file(s) to see the model of the stadium Typhoon......
Wire mesh curtain wall door for wire mesh wall
Mon, Sep 17, 2012 at 2:57:36 PM
Importing a 3D mesh model into Revit and creating the mesh to solids
Thu, Dec 15, 2016 at 9:20:20 AM
Editting a mesh in Revit, is it possible?
Thu, May 23, 2013 at 7:42:42 PM
See through pattern for mesh panels?
Tue, Nov 16, 2010 at 2:46:37 PM
Wire Mesh Handrail
Mon, Dec 20, 2010 at 3:58:42 PM
Page generation time: 1.8161
