28 Users Online (26 Members):
Forums >> Revit Structure >> Technical Support >> footing queries
5 Posts No Rating |
hi all, i am working on revit structure 2009 and i am facing this strange problem while working with isolated foundations. as example : i have created a footing F1-1500x1500x500 and i have placed it at several places as required. now i need to create F2-1500x1650x500 for other columns. the moment i create and place F2 in the building, from the foundation schedule the type marks F1 & F2 vanishes and numbers of footings also vanishes. it considers F1 & F2 as same as the first dimension 1500 is common for both.this happens always when the length of two foundations are identical. am i going wrong somewhere ...please help me out thanks asit
It sounds like you have duplicate type or instance marks. Then when you place one the schedule doesn't know how to read it. Either that or you have duplicate information in your schedule. HTH JB
5 Posts No Rating |
thanks actually problem was with sorting the footing by width in ascending order i.e. in the schedule of foundation when i changed the sorting order from 'by width' to 'by type mark' , the problem solved ...my mistake only...  thanks again asit
footing queries |
Sun, Nov 9, 2008 at 12:51:00 AM
Continuous Wall Footing ? |
Thu, Aug 23, 2012 at 1:59:47 PM
13
Foundation Top of Footing (when Level is something other than 0'-0") |
Fri, Jan 29, 2016 at 1:40:13 PM
Top of Isolated Column Footing forced to snap to bottom of column |
Mon, Jan 13, 2014 at 7:41:43 PM
Wall profile footing issure |
Fri, Oct 3, 2014 at 7:06:49 AM
