25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Remove items from a Design Option?
36 Posts No Rating |
Does anyone know how to remove items from a design option? It is very easy to ADD items to design options, but I havent found a command to REMOVE items. I accidentally put too many existing walls in my design options.
Autodesk Revit MEP 2015 |
Select item while in the design option and hit the delete key! .... or did you want to move them out of the deign option to the base model?
Yes, I just want to put it back in the base model. They are Existing items that are not affected by any options.
You can copy - paste
i think WWHub mean to say cut - paste. if you copy you will leave the objects in the option, which you do not want to do.
5 Posts No Rating |
Cut - Paste worked. Thank you.
Design Option Issue - walls in 1 design option cutting thru a 2nd option |
Thu, Oct 21, 2010 at 11:55:04 AM
Design Option view setting |
Fri, May 16, 2014 at 8:02:11 PM
Design Options - black hole. |
Wed, Feb 14, 2007 at 12:54:40 PM
Design Option Sharing |
Mon, Dec 6, 2010 at 10:02:19 AM
12
Railing wont host to stair created in design option |
Mon, Oct 24, 2011 at 3:54:39 PM
