Forums >> Revit Building >> Technical Support >> RCP IN FLOOR PLAN VIEW
Fri, Oct 31, 2008 at 1:06:56 PM | RCP IN FLOOR PLAN VIEW
garyb
If you couldn't guess by the title, I'm using Revit MEP 2009. I am trying to find a way to show the reflected ceiling plan, that you can see in a ceiling plan view, on a floor plan view. We typically like to show to reflected ceiling grid on our plans, but I'm having one of those days where Revit is pissing me off, once again, and I could throw my computer at the next person that walks by my computer. It probably has something to do with my view range. Also the way we have our model showing is custom to the Revit MEP default view. We clean up the architectural model so in our central file, under visibility graphics override, then Revit links, usually it will say "By Host View." Well we change it to custom and change to settings to the following:
 Linked View: coordinate with whatever floor level we are on. (Ex. first floor for the first floor plan view, second floor for the second floor plan view, etc.)
 View Range: <By Linked View>
Phase: <By Linked View>
Phase Filter: <By Linked View>
Detail Level: <By Host View>
Discipline: Coordination
Color Fill: <By Host View>
Object Styles: <By Host View>
Nested Links: <By Parent Link>
And this is typical for ever floor plan and ceiling plan view for Electrical, Mechanical and Plumbing. Any advice or information would be a lot of help.
Thanks in advance!
Fri, Oct 31, 2008 at 2:39:57 PM | RCP IN FLOOR PLAN VIEW
Don't think of it as a floor plan with RCP...  Think of it as a RCP with a view range to the floor and a cut plane at normal floor plan location.
Sun, Nov 2, 2008 at 1:32:31 PM | RCP IN FLOOR PLAN VIEW
garyb
So basically, a ceiling plan that has a view range of a floor plan. That's what I'm guessing.
see RCP on plan view
Mon, May 17, 2010 at 4:50:56 PM
Unable to view RCP
Wed, Apr 1, 2009 at 3:55:11 PM
View Range/Plan Region Visibility Controls in RCP
Wed, Feb 1, 2012 at 11:20:32 AM
family that appears in RCP but not in Plan
Tue, Sep 22, 2009 at 8:31:34 AM
Orienting plan regions
Thu, Sep 3, 2015 at 2:59:30 PM
Page generation time: 2.0398
