22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> custom curtain walls
hi, i am practising revit through tutorials and books and am finding some problems while doing so. presently i am doing a tutorial on custom curtain walls from an online tutorial. but i am getting stuck at some places because the tutorial is not clear enough. the pdf of the tutorial i am uploading . see if someone can help me. the tut is on custom curtain walls but i am not able to figure out in which family the author is trying to make the mullions. secondly , how do i insert a array based parameter in a family as stated in the tut. i hav only done dimension based parameters till now.
Hi, you can use the "Metric/Imperial-Profile" or "Metric/Imperial - Profile-Mullion" (like you can see in the image attached) to create those "Profiles"....
The mullions are created in the profile - mullion family.
hey , even i tried with the proflie family but the problem is that the tut. asks to parameter the height within the family editor which cannot be done with the profile family . secondly if i use it as a profile and try to use it in curtain walls i get an error saying that the profile is more than one loop so not possible to use.. so i think the mullion is not made as a mullion but as a generic model and then the horizontal and vertical are created separately and then assembled in one component . correct me if i am wrong .
Yes, reading through the tutorial, the mullions were not created as profiles but as generic models as you suggest, although the tutorial does not mention this.
Loading Custom Curtain Wall Panel into file |
Mon, Sep 15, 2014 at 9:19:41 AM
Inserting Custom Curtain Panels Into Angle/skewed |
Fri, Apr 30, 2010 at 4:50:44 AM
Custom-made Curtain Walls |
Fri, Aug 20, 2010 at 4:18:23 AM
Angled Curtain Walls - fillets and nested |
Thu, Apr 23, 2009 at 5:42:47 PM
Curtain walls |
Mon, Nov 7, 2011 at 10:28:33 AM
