Forums >> Revit Building >> Technical Support >> draw lines in existing conditions
Fri, Oct 31, 2008 at 11:38:55 AM | draw lines in existing conditions
Arual
I'm trying to add lines to my ex'g conditions plan.  When I draw them they default to the "new construction phase". this is the message:
None of the created elements are visible in Floor Plan: 07 PENTHOUSE Demo View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
I know how to change the properties, but can i chage the defalut so that I don't have to chage each line individually? Thanks!
Fri, Oct 31, 2008 at 11:49:39 AM | draw lines in existing conditions
Are you drawing model or detail lines?  I sounds like you are drawing model lines and they are really out of your view range.
You probably should be drawing detail lines found under the drafting tab.
Also - make sure lines are on in your VG settings.
Mon, Nov 3, 2008 at 9:15:31 AM | draw lines in existing conditions
Arual
Thanks,  I was actually drawing model lines and I eventually got them to appear,  but is there a way to change the default so that when you draw a line it doesn't automatically become a "new construction" line?
You just need to develope good habits.  Hard at first.
Edited on: Mon, Nov 3, 2008 at 10:38:06 AM
Mon, Nov 3, 2008 at 10:37:26 AM | draw lines in existing conditions
Model lines are drawn from the model tab.  Detail lines are drawn from the drafting tab.
Locking Existing Conditions
Sat, Apr 12, 2025 at 5:29:49 AM
Existing Stairs
Mon, Aug 10, 2009 at 1:36:53 AM
appearance of line types of existing objects in a "new construction" views
Sat, Feb 26, 2005 at 10:35:37 AM
Wall infill - Existing and New
Fri, Jan 7, 2011 at 10:29:27 AM
Existing Wall Rendered
Sun, Jul 27, 2008 at 5:23:30 PM
Page generation time: 2.6314
