Forums >> Revit Building >> Technical Support >> Render stops after finalgather pass on larger images
Thu, Oct 30, 2008 at 7:36:37 PM | Render stops after finalgather pass on larger images
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
Using Revit 2009 with latest build
Im trying to render a large 3k image (printer setting at 75 dpi) for a presentation but the rendering stops just after its finished the FG pass.  The rendering dialoge is alittle annoying as it dosent allow you to set a specsific render size.
My Pc - 2.4Gig Quad, 4gig ram, Nvidia GeForce 9800 GX2
Has any1 else had this issue
Fri, Oct 31, 2008 at 9:02:46 AM | Render stops after finalgather pass on larger images
Sounds like you ran out of memory.  Did you go to your task manager and look at your performace to see if REVIT was still running (doing something that you can't yet see)?  You can also monitor your memory there.
Thu, Apr 15, 2010 at 9:48:34 PM | Render stops after finalgather pass on larger images
albertstwrt
4 Stars: 8 Votes
I'm having the same problem, but I have 8GB of RAM with a Quad running at 3.6 Mhz..... I didn't see nothing in my task manager far as memory loses.
Missing Render images
Sun, Feb 12, 2012 at 7:36:48 AM
render specific frames of a walk through
Fri, Oct 7, 2011 at 3:39:42 PM
Revit 2011 Rendering stops at 50%
Sun, Dec 5, 2010 at 10:08:39 AM
render appereance images missing
Wed, May 11, 2016 at 3:12:17 AM
RPC render images missing
Wed, Nov 24, 2021 at 11:45:42 AM
Page generation time: 1.0197
