13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> model into drafting view
50 Posts No Rating |
i am trying to bring a revit drawing into the drafting view.
how can i import this drawing done as a model into drafting view and be able
to edit it without affecting the original model.
since revit automatically generates sections and elevations from the model, i sometimes end up with the section or elevation showing more than required for a plot
for instance basement walls show on an auto-generated elevation when all i'll need to plot is a base line showing the grade and basement walls shown as hidden lines.
so basically i am asking for a way to do this without deleting the basement wall in the model if i don't want it to show up in a 2d plot.
excuse the long question and thanks for replies and suggestions
Turn off the elements you don't want to see in the section.
Change the view extents of the section so it doesn't show information beyond it.
Use the linework tool to change linetypes to be dashed/invisible etc...
Use filled regions to conceal items that can't be rectified by the above or modelling.
Converting Model Views to Drafting Views |
Fri, May 13, 2016 at 2:13:29 PM
drafting view from model view |
Mon, Jun 29, 2015 at 7:27:31 AM
Model view section cut refer to a drafting view |
Wed, Nov 13, 2019 at 5:44:08 AM
Flagging new Drafting Views - How to reference a drafting view detail? |
Wed, Aug 1, 2007 at 10:26:29 AM
drafting from model |
Sat, May 14, 2005 at 6:39:37 PM
