Forums >> General Discussion >> Revit Project Management >> REPEAT COMMAND?
Thu, Oct 30, 2008 at 8:39:57 AM | REPEAT COMMAND?
MARS1276
1 Stars: 1 Votes
I am currently learning Revit and using it for my company.  Still, we use AutoCAD which has a feature I would like to know if Revit has as well.  Is there a keyboard shortcut key(s) that will redo the last command?
I am drawing details and find that whenever I use the detail lines tool and escape one too many times I am back in the modify command.  Is there any shortcut key(s) that will allow me to use the previous tool/action without having to move my mouse back over to the detail lines button itself?
If  anyone knows the proper shortcut command to enter into the Revit KeyboardShortcuts.txt file I would like to know what it is.
Thanks,
 Marshall Loveless
Architectural CAD Draftsman
Titan Construction & Engineering Services
Rensselaer, Indiana
Fri, Oct 31, 2008 at 8:06:32 AM | REPEAT COMMAND?
JRMello
I have my Detail Lines mapped to the keys DL. Just hit those two in sequence and you're back in the command.
Fri, Oct 31, 2008 at 9:43:11 AM | REPEAT COMMAND?
MARS1276
1 Stars: 1 Votes
Thanks, I got that to work.  I didn't like the idea of hunting and pecking with one hand or taking the other hand off my mouse; so I changed DL to DD and it works splendid!  I tried editing the KeyboardShortcuts.txt file yesterday but I could not get any of the new additions I had made to work.  Any ideas why?  Each time I closed out of Revit and reloaded it.  There are still many shortcut keys I would like to assign; but I couldn't get it to work the first time so I haven't tried it again.  Any ideas where I might have gone wrong?  Any ideas what I should do to get them to work?  Is there any way to re-assign my *.txt file within Revit without closing it down and re-opening it?  I looked into the Help index but there was little in the way of help with this.
Anybody?
Thanks.
Fri, Oct 31, 2008 at 9:55:58 AM | REPEAT COMMAND?
JRMello
Clearly, syntax is important, so I make sure all my text lines are in the same format as the shortcuts that were there before. If there's a semicolon at the begining of a line, it is deactivated. But the other thing I can accross was that sometimes if you have the same shortcut assigned to two commands you will see a message in the Status Bar asking which one you want to use. You might look for that and change the one you don't want. HTH.
Fri, Oct 31, 2008 at 10:01:42 AM | REPEAT COMMAND?
MARS1276
1 Stars: 1 Votes
THANKS!
repeat command shortcut key??
Tue, Aug 19, 2008 at 2:15:12 PM
Repeat Last command/Enter
Fri, Oct 29, 2010 at 7:53:36 AM
copy rotate and repeat command
Thu, Dec 22, 2005 at 3:44:41 AM
Repeat last funtction?
Sat, Aug 6, 2005 at 7:16:57 PM
Why can't I make an "accelerator" so that space bar repeats last command?
Wed, Jan 9, 2008 at 12:35:49 PM
Page generation time: 0.6016
