27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Installing 8
3 Posts No Rating |
When installing revit 8 I chose to keep revit 7. An error message came up "EULA.cab is corrupted error: the system cannot find the file path specified". Then it seemed to load ok. Still on 7 a few days later things went crazy- got into some strange software loop. Could the install of 8 have caused this? I have now dumped 8 (for the moment) any ideas? (I'm on a dell precision M60 with 1 gig of ram) Thank you-
5 Posts No Rating |
Not sure about the error.
Is there a problem with moving all of your work to 8? Once the new version is out, I dont see any reason why you would need to use and old version.
Brett
Having multiple versions should have no effect on each other. I currently have 6.1, 7, & 8 installed and have no problems.
I'd suggest re-installing 7, then installing v8 after that if you require both versions on your system and i'd suggest that most people should for the first couple of months of a new release.
INstalling solar CCTv |
Fri, Oct 12, 2012 at 2:16:18 PM
Problem installing Revit 2014 |
Sun, May 5, 2013 at 5:05:12 PM
Can I change my default Imperial Style to Metric without re-installing? |
Fri, Feb 19, 2010 at 6:56:31 AM
problem installing |
Tue, Apr 19, 2011 at 3:23:12 AM
Trouble Installing RAC 2010 x64 |
Thu, Oct 1, 2009 at 3:47:49 AM
