Forums >> Revit Building >> Technical Support >> Make annotation on wall-mounted family show on floorplan
Wed, Oct 29, 2008 at 11:05:12 AM | Make annotation on wall-mounted family show on floorplan
eglover
eglover Avatar
I need to add an annotation to a wall-mounted lighting fixture that will show on a project's floorplan. The issue is that when you create a face-hosted family, looking at the face is considered the "floorplan." An annotation on the floorplan view of the family will only show up on an elevation view of the project. To place an annotation that will show up on the floorplan of the project, it needs to be placed on the back view of the family. While in the back view, the "symbol" tool is grayed out. The only way arround this I've found is to open a family from the existing library in which the annotation behaves the way I need and then modify everything and resave it. This is very messy, and there has to be a more direct way to do this. Any ideas?
~E
{Having fun with family building}
Running Revit MEP 2009 on Windows XP
Wed, Nov 12, 2008 at 1:41:40 PM | Make annotation on wall-mounted family show on floorplan
eglover
eglover Avatar
Just thought I'd update in case it can help (or save effort for) someone else:
Electrical families show annotations in all views (presumably because many of their parts wouldn't show up well on a floorplan). If you need the wall-hosted item to come up under the right discipline, behave the way it's supposed to, carry the correct information, and show an annotation, it seems you are out of luck.
It's a shame, because there doesn't seem to be a reason to just gray-out the symbol button in some views. This will continue to cause me problems, so if anyone finds any type of solution, I would really appreciate it.
*Edited to fix typos
Edited on: Wed, Nov 12, 2008 at 1:55:40 PM
~E
horizontally mounted duplex receptacles
Mon, Feb 22, 2010 at 8:02:04 AM
Ceiling Mounted Receptacles
Mon, Mar 19, 2012 at 12:19:14 PM
Revit 2008 wall mounted family placement issue
Mon, Jun 20, 2011 at 3:19:51 AM
wall mounted toilet wall error
Wed, May 6, 2009 at 3:41:37 PM
Changing family from wall mounted to ceiling mounted
Mon, Nov 16, 2009 at 2:19:09 PM
Page generation time: 1.5468
