30 Users Online (28 Members):
Forums >> Revit Building >> Technical Support >> change matirials in dwg block
12 Posts No Rating |
Hi I downloaded block and I want to change the matirials, how can I do that? I can't explode it or something. Please - help
Hi, in your CAD file change by colors what do you want to apply different materials, don't use the same color for 2 different material, then when you import for revit go to Settings-Materials and you have there several materials like this: "Render ###,###,###" and so one, this is the colors of that "Block" then change those "Render ###,###,###" for the materials you want...
Edited on: Wed, Oct 29, 2008 at 5:19:18 AM
I'm not sure what you mean. You can't add materials to a dwg block. It does not ussually make sense to explode a dwg in a Revit project although this is posible. Please confirm what you are trying to achieve.
if it is a dwg block this may help http://www.revitcity.com/tutorials/how_to_grow_your_family/ HTH
Revit 2012 Export To DWG. Titleblock exported as Block. |
Wed, Jun 12, 2013 at 6:16:23 PM
Importing and rendering a model in DWG format [ 1 2 3 ] |
Sun, Aug 30, 2009 at 1:56:49 PM
31
How to import my title block from AutoCAD? |
Mon, Sep 10, 2007 at 4:25:43 PM
12
Title Block revision numbers |
Tue, Feb 26, 2013 at 12:34:23 AM
raster image issue when exporting titleblocks to dwg / autocad |
Tue, Sep 9, 2008 at 12:12:42 PM
