18 Users Online (16 Members):
Forums >> Revit Systems >> Technical Support >> conditional formatting yes no parameters
I am attempting to toggle several yes no parameters based on one conditional format. I have a number of ports on a manifold with yes/no toggles. I would like to use the following formula to toggle each one (the manifold length already adjusts based on the # of ports) if (# OF PORTS = 10,1,0) ----- to be used to toggle port 10 if (# OF PORTS = 9,1,0) ------ to be used to toggle port 9 and so on attached is my in progress revit family.... every time I use the above formula I get an inconsistant unit error. All parameters in question are instance parameters, the only inconistancy is that the # of ports is a shared parameter and the yes/no's are family parameters but thats never been a problem before?
I think the "Shared parameters" only work with "Type Parameters" not "Instance"....
I double checked just now, but the # of ports is definately a shared instance parameter, and the yes no toggles are definately a family instance parameter....... yes does = 1 and no does = 0 right?
Just for the heck of it I tried making the # of ports a family parameter as well (even though I wanted it to schedule) but I still got the same error so thats not it either?
ok got it from the users guide.... yes no parameters imply yes if the statement is true so all I needed was = #of ports < 10 --> for toggling port nine = # of ports <9 --> for toggling port eight and so on......
Arch 2012 Conditional Formatting |
Tue, Sep 18, 2012 at 11:08:38 AM
can you hide zeroes in schedules? |
Tue, Feb 14, 2012 at 1:26:55 PM
Advanced Family Modeling |
Thu, Mar 16, 2006 at 9:18:30 PM
Conditional statement |
Thu, Jun 27, 2013 at 9:58:47 AM
Conditional Parameters Setting In Revit |
Tue, Jun 26, 2018 at 7:25:52 AM
