Forums >> Revit Building >> Technical Support >> Revit Architecture 2009 - cannot open file using "file: open"..any help?
Mon, Oct 27, 2008 at 3:32:03 PM | Revit Architecture 2009 - cannot open file using "file: open"..any help?
KevCorey
I'm using Revit Architecture 2009 and I can start the program just fine. Problem comes when I go to the "File" menu and choose "open"... Revit just hangs and I have to ctrl-alt-delete to get out of it. No dialog box pops up at all. If I double click on my file in Windows Explorer it opens just fine though... Anyone else had this issue?
Mon, Oct 27, 2008 at 3:41:53 PM | Revit Architecture 2009 - cannot open file using "file: open"..any help?
4 Stars: 205 Votes
Did you check VIRUS??? did you Update (SP) RAC 2009??? are new 64bits?
Mon, Oct 27, 2008 at 4:54:44 PM | Revit Architecture 2009 - cannot open file using "file: open"..any help?
KevCorey
We dont have 64 bit machines...I have updated to the latest build though.... still checking for a virus, but when I opened Revit Architecture 2008 the File Open option worked fine. I figured it was a bug with RAC 2009. Currently re-installing the program (for the second time)....
Tue, Oct 28, 2008 at 4:23:44 AM | Revit Architecture 2009 - cannot open file using "file: open"..any help?
4 Stars: 205 Votes
Yeah, try to re-install because i never heard this kind of "Bug"...
Wed, Oct 29, 2008 at 12:13:48 AM | Revit Architecture 2009 - cannot open file using "file: open"..any help?
will2play
will2play Avatar
Banging your head on your monitor, trying to create a Mitered-Corner Window?  In this week’s Rockstar Hour I'll show you how to create Mitered-Corner Windows.      The Rockstar Hour is a opportunity to attend a free hour of web-based Revit training.
Join the meeting here.
https://www1.gotomeeting.com/register/353233504
Rockstar Hour:
9:30 AM – 10:30 AM PST every Wednesday
See you there,
Know someone else who's been working on this problem?  Connect them with the Rockstar Hour.
Will Harris
www.will2play.com
www.will2play.com
Wed, Oct 29, 2008 at 11:42:44 AM | Revit Architecture 2009 - cannot open file using "file: open"..any help?
KevCorey
Problem solved. We use dual screens and my display properties were screwed up. Once I edited them, my dialog box (which was there all along, just lost somewhere in space) showed up fine.
 Thanks for your suggestions anyway
Wed, Jul 28, 2010 at 2:34:26 PM | Revit Architecture 2009 - cannot open file using "file: open"..any help?
mand0003
Thanks for posting your solution, I was just having the same exact problem, very frustrating.  I'm in the field today, so don't have my additional screen.  I went to control panel and changed the screen resolution and voila, there was the open dialog box.  Goofy.
Cannot Open File
Tue, Mar 30, 2010 at 9:18:58 AM
Revit crashes when i go to "File- Open" WHY!?
Fri, Apr 4, 2008 at 8:36:12 AM
"Inches to the fourth power" Notice wont let me open my file
Tue, Aug 21, 2012 at 10:51:54 AM
Can't open a Revit file. Never saw this error message before!
Thu, Aug 7, 2008 at 4:57:55 PM
Opening 2008 file in 2009 causes "Unrecoverable error" crash
Tue, Jul 28, 2009 at 1:36:33 AM
Page generation time: 2.4115
