Forums >> Revit Building >> Technical Support >> Wall Detail Level
Mon, Oct 27, 2008 at 12:28:03 PM | Wall Detail Level
maranelloboy
3 Stars: 2 Votes
Is there any way of changing what layers of a wall (or floor or roof for that matter) display on the different detail levels?  Our consultants want more simplified walls than what we're sending them in our CAD exports, but they still need to be able to have the wall core defined.  The first picture is what we get with the detail level set to medium and fine, the second picture is set to course, and the third picture is the desired result at medium.
Mon, Oct 27, 2008 at 1:53:52 PM | Wall Detail Level
Look at your export-layers file.  Structure 1&2 / Finish 1&2 / air-layer / membrane as well as common edges are all definable layers.... you can set up what will work best for you by experimentation.
You just need to understand what hapens when you move items from core to finish or the oter way around.  Your HELP will explain the rules on cleanup using these values.
Mon, Oct 27, 2008 at 2:14:53 PM | Wall Detail Level
maranelloboy
3 Stars: 2 Votes
Thanks.  I'll try it out.
Mon, Oct 27, 2008 at 2:24:41 PM | Wall Detail Level
tim123
4 Stars: 19 Votes
If there aren't too many walls you can create a duplicate view for the client and use the pen tool to make the lines that you don't want invisible.
Mon, Oct 27, 2008 at 2:25:20 PM | Wall Detail Level
maranelloboy
3 Stars: 2 Votes
Mon, Oct 27, 2008 at 2:25:34 PM | Wall Detail Level
tim123
4 Stars: 19 Votes
Course Detail Level Exposes Wall Ends
Fri, Nov 4, 2011 at 1:16:57 PM
Detail level - arch vs structure
Tue, Jan 20, 2009 at 9:05:50 AM
fine detail missing on duplicated wall, plan view??
Mon, May 1, 2006 at 8:31:20 PM
Revit Detail Level fill pattern, Texts in Elevation and Section's Symbols
Mon, Jul 30, 2012 at 7:12:54 AM
Detail Level
Thu, Apr 14, 2011 at 4:19:07 AM
Page generation time: 0.7584
