11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Site Modeling
13 Posts No Rating |
I tried to generate a topo from a set of plines that where draw in auto cad at the correct elevation and found that revit is triangulating some the geometry completely wrong. I have tried
to clean up the autocad file and join the p-lines but still get a lot of strange points that do not relate to the draw autocad topo lines.
I was wondering if it would be best to trace over the autocad file with the point tool,
or is there specific setting under the site setting menu that should be used.
My topo lines are representing a 1'-0" elevation change. I attached the auto cad file and
and a view generated from the revit file.
Please advise.
Fabian
Post edited on 2005-05-09 23:18:19
Post edited on 2005-05-09 23:20:05
5 Posts No Rating |
I dont think you attached the DWG file.
The topography tool usually works pretty well from imported DWG data. Are you sure that the DWG file is pretty clean ie. there are no stray entities anywhere.
Another thing to try is, when you are creating your topography, make sure you only select the layers that contain your contour data.
Brett
Maybe try to play around the site setting but resetting your contour line interval as for it to reflect better on your site modelling...I was experiencing some problems with the display of the site modelling and once I reset some of the setting there, it turns out ok...Properly this is the some cases as your contour line is just 1'-0" elevation differences
----------------------------------- Life is never easy but nor it should be complex. Just stay simple  |
Learn Site Design and Modeling in Revit for Free |
Fri, Oct 11, 2013 at 2:57:55 PM
Site Modeling Tutorial |
Mon, Jul 25, 2005 at 1:57:32 AM
Modeling Site Utilities (i.e., SS, SD, Waterline....) |
Wed, Mar 30, 2011 at 9:17:08 PM
Site Plan??? |
Mon, Jan 25, 2010 at 12:47:43 PM
Site Orientation |
Fri, Jul 1, 2005 at 3:52:38 PM
