Forums >> Revit Building >> Technical Support >> Deleting Problems (Revit 2009)
Fri, Oct 24, 2008 at 2:38:12 PM | Deleting Problems (Revit 2009)
jcallis
Hello Everyone,
 I have a pretty big problem. When I draw something in Revit, then delete it, it still shows up in all other views! Also if I add a door to a wall and decide to delete it a put in a smaller door the original opening for the larger door remains. Has anyone had this problem? Any help would be greatly appreciated.
 Thanks,
Justin
Fri, Oct 24, 2008 at 2:59:34 PM | Deleting Problems (Revit 2009)
bradleymatthew
Are you using stock Revit doors?  Do the doors function properly when placed originally?  Are you working in worksets with other users?
Bradley
Fri, Oct 24, 2008 at 3:21:09 PM | Deleting Problems (Revit 2009)
jcallis
yes, yes, and no. it even does it with a plain wall with nothing in it. I draw a wall and then delete it then try to draw another one in its place and it says that tere is a wall currently there when ther isnt.
Fri, Oct 24, 2008 at 3:48:17 PM | Deleting Problems (Revit 2009)
bradleymatthew
Are you using Phases?
Bradley
Mon, Oct 27, 2008 at 7:28:08 AM | Deleting Problems (Revit 2009)
jcallis
yes I am using phases
Mon, Oct 27, 2008 at 8:19:10 AM | Deleting Problems (Revit 2009)
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
How are you deleting the object. Are you using a menu or button command or are you pressing "E" on the keyboard. If you are using the keyboard you are not deleting the object you are hiding it in view. Try click the lightbulb icon at the bottom of the screen after "deleting" the Item and make sure it is not there.
Edited on: Mon, Oct 27, 2008 at 8:25:45 AM
Mon, Oct 27, 2008 at 9:04:48 AM | Deleting Problems (Revit 2009)
jcallis
Its still there after I use the keyboard. What am I supposed to use to completely delete an element/item?
Thanks,
Justin
Mon, Oct 27, 2008 at 9:17:50 AM | Deleting Problems (Revit 2009)
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
The problem is the "E" keyboard shortcut is the shortcut key for "Hide Element in View". You will need to use either the Delete Key, "DE" on the keyboard, Right click delete or Edit Menu delete to actually delete an item.
Mon, Oct 27, 2008 at 9:21:15 AM | Deleting Problems (Revit 2009)
jcallis
ok, wow that sucks. I have been using the E key on the keyboard. I have only been working with Revit for about 2 1/2 weeks and I came from ADT so I am used to using the E key.
Thank you so much for the help,
Justin
Any known problems converting projects to 2009 form 2008?
Thu, Aug 21, 2008 at 5:49:13 PM
Anyone else having crash problems with 2010? [ 1 2 3 4 ]
Wed, Jan 6, 2010 at 2:08:47 PM
52
Deleting uploaded objects
Wed, Nov 30, 2016 at 11:36:56 PM
Help activating revit 2009
Mon, Jun 29, 2009 at 8:26:40 AM
Black Screen Problems
Tue, Jan 12, 2010 at 8:24:33 PM
Page generation time: 2.2843
