21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Superscript/subscript/degree text symbols in Revit
16 Posts No Rating |
Does anyone know if this is possible? I have recently moved to Revit from ACAD and am finding the text capabilities in Revit a bit frustrating!
Cheers!
Use the character map shortcuts:
Hold "Alt" and type "0186" is your degrees symbol º
Alt 0179 ³ cubed
Alt 0178 ² Squared
Alt 0216 Ø Diameter.
HTH.
Excellent! Thanks very much!
To make text appear slightly above (superscript) or below (subscript) your regular text, use these keyboard shortcuts:
- For superscript, select the text or number that you want, and then press Ctrl, Shift, and the Plus sign (+) at the same time.
- For subscript, select the text or number that you want, and then press Ctrl and the Equal sign (=) at the same time.
aehrl....
You realize functionallity was different in 2005?
Did you test out your process. It doesn't work in 2014. It looks correct until you finish the text. Then it reverts to normal text.
Edited on: Fri, Sep 26, 2014 at 8:07:28 AM
1 Posts No Rating |
Still broken in 2016
Text Symbols? [ 1 2 ] |
Tue, Apr 28, 2009 at 2:43:34 PM
22
Symbols |
Fri, Nov 25, 2005 at 5:29:24 PM
Text symbols [ 1 2 ] |
Tue, Mar 10, 2015 at 10:14:14 PM
18
Symbols in Revit |
Mon, Feb 6, 2012 at 7:05:09 PM
how to type degree symbol in text |
Mon, May 21, 2007 at 11:54:29 AM
