22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Attching objects to a toposurface
2 Posts No Rating |
is there a way to attach an object such as a side-curb or a rpc object to a topo surface which is sloping (except for viewing it from all elevations and then moving it accordingly)? I do not know how to make my curb fall with the sloping surface and this seems to take ages manually.
Site "is the weakest link" in REVIT at this time. You can not do what you want - you end up having to do in place families or use walls and edit the profile.
2 Posts No Rating |
Thanks WWhub, not what I wanted to hear but maybe Revit 2010 wil have this option.
I don't know if this is what do you need but, pick in the family you want (rpc...) pick in "EDIT", in Settings-Family and category parameters choose "Site" and uncheck "Always vertical", save and load to project...
17 Posts No Rating |
WWHub is correct, the site tools in Revit are horrible to use. However, I have attempted this work around a couple time. In order to get my curbs, sidewalks, etc to follow the slope of my topo, I use a floor or a pad. Then slope the floor to match my topo by editing the corner elevation points. To make sure my curb is at the correct elevation, I use the spot dimension tool on the topo, and then edit my floor to match (+ the appropriate curb height). Hope that makes some sense.
Flat Toposurface |
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface&subregion problems |
Thu, Apr 16, 2009 at 1:47:06 AM
Toposurface in Elevations |
Thu, Aug 27, 2009 at 1:51:06 AM
what is the easy to do toposurface |
Mon, Feb 27, 2006 at 8:44:07 AM
14
Toposurface |
Tue, May 11, 2010 at 9:04:45 AM
