Forums >> Revit Building >> Technical Support >> Colour Fill Missing from some rooms
Fri, Oct 24, 2008 at 5:55:30 AM | Colour Fill Missing from some rooms
Suzanne84
I have a colour fill applied to a plan view which is picking up one of the parameters of the room. Most of the rooms have coloured fine apart from 1 or 2 that are showing up blank - despite the parameter being filled in correctly. If i move the room elsewhere the colour shows up fine. I have turned off floors, ceilings roofs - anything that could be in the way - I have checked the sections to see if there is anything floating there and can't find anything. I have deleted and replaced the room and checked that the same room number isnt being used twice. When printed it still doesnt show up. Any clues?
Fri, Oct 24, 2008 at 6:34:56 AM | Colour Fill Missing from some rooms
Suzanne84
I've managed to fix this myself - there were some additional walls within these rooms (vocational training workshops with open bays built in side to plaster/tile etc) when I changed these walls to non-room bounding the colour fill appeared - revit just didnt like these walls.
Fri, Oct 24, 2008 at 8:24:58 AM | Colour Fill Missing from some rooms
The room definition is the center of the X.  Because you had these walls that should not have been room bounding, you may have had your room placed in a very small space.   Next time, move the center of your room to the center of the room and you will recognise these room bounding walls eariler.
customising colour fill legends
Sun, Jan 4, 2015 at 1:09:25 PM
Area plan issue
Fri, Dec 30, 2005 at 1:24:55 AM
Colour Schedule Question
Sun, Feb 8, 2015 at 10:05:51 PM
INCONSISTANT COLOUR WHEN PRINTING
Wed, Aug 16, 2017 at 2:12:47 PM
Area Plans and Colour Fills
Fri, Jul 13, 2007 at 9:28:23 AM
Page generation time: 0.6399
