Forums >> Revit Building >> Technical Support >> Cantilevered roof cable an brackets
Fri, Oct 24, 2008 at 12:34:12 AM | Cantilevered roof cable an brackets
jonelizares
Im trying to make the brackets and cabel that holds up teh cantilevered roof on my building. does anyone know how to go about making a family for that? my approach is making the brackets seperately. i have the horizontal adn the vertical. i created parameters to adjust its hieght adn sitance from one another. i need to make the cable wire part of it. i want the ends of the cabel wire to be bases at the brackets so taht when i adjust the height and/or length of the brackets from one another that the cabel wire will strecth/shrink and adjust its angle to always remain based at teh brackets. any suggestions?
Fri, Oct 24, 2008 at 3:51:55 AM | Cantilevered roof cable an brackets
4 Stars: 205 Votes
Hi, in the same family you can create 2 types, 1 for Cantilevered and the second type for brackets, then create in each other a "Visibility" parameter (Yes/no) so you can control the visibility in the family what do you want to see, but if you go to the "Tutorials" from autodesk you have there a "Family tutorials" and has an example with this...
Tension Cable
Sun, May 27, 2012 at 6:54:39 AM
How do you make cantilevered Roofs?
Mon, May 15, 2006 at 7:17:59 PM
Detail Lines in Brackets?
Thu, May 6, 2010 at 12:38:47 PM
How to do Cable Tray with Real Material Color (Not just filter color)
Wed, Feb 18, 2015 at 3:14:07 AM
Cable tray tee
Tue, Nov 1, 2016 at 7:29:06 AM
Page generation time: 0.2202
