Forums >> Revit Building >> Technical Support >> drafting from model
Mon, May 9, 2005 at 2:38:39 PM | drafting from model
yoiyoi
i have a drawing in revit 7 but would like more flexibilty regarding changing line types , line thickness, hatch patterns etc. for example a section view generated from the model shows too many lines i can do without is there a way of using the original model as base drawing in, say, drafting view and importing components or drawing lines over it to achieve an output which is not just a 2d view of the model any help appreciated
Tue, May 10, 2005 at 2:26:50 AM | RE: drafting from model
brett05
Without seeing the file, it's a bit hard to comment. A couple of things to try --> Change the detail level to medium or coarse. Adjust the clipping plane of your section to give you a 'thinner' slice through the building. Brett
Thu, May 12, 2005 at 10:43:39 PM | RE: drafting from model
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
you can also use the linework tool, set to invisible lines to remove unwanted edges in the section...
Sat, May 14, 2005 at 6:39:37 PM | RE: drafting from model
yoiyoi
thanks guys, where can i find the invisible lines option ? it doesn't show up in my line type selector drop down list
Converting Model Views to Drafting Views
Fri, May 13, 2016 at 2:13:29 PM
batt insulation fill pattern (drafting)
Thu, Nov 1, 2012 at 1:03:19 PM
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
drafting view from model view
Mon, Jun 29, 2015 at 7:27:31 AM
Drafting a model based detail
Thu, Mar 25, 2010 at 9:35:13 AM
Page generation time: 1.3262
