Forums >> Revit Building >> Technical Support >> Parametric steel deck
Sat, May 7, 2005 at 4:15:38 PM | Parametric steel deck
zergio
Does someone know how to make a parametric steel deck, that shows up in section view as well? I've been doing extrusions in section view to make up for the steel part, but I'm guessing that there's got to be an easier way.
Sun, May 8, 2005 at 6:10:36 PM | RE: Parametric steel deck
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Using Version 8. Structural Framing System, just load the appropriate beam type then set the spacing and draw the boundary and direction...
Mon, May 9, 2005 at 1:10:07 AM | RE: Parametric steel deck
Arnel Aguel
I guess what he meant is that a floor steel deck supporting the slab but will automatically cut a void to form the steel pan. It is actually there in version 8 as another layer of the slab properties but it wont cut the slab to form void in the slab. This issue has also been raised in the other forum but no one gives an exact explanation as to what is the purpose of the said new layer function of the slab the metal deck.
steel deck profile
Mon, Apr 24, 2006 at 4:59:54 PM
steel deck
Wed, Jan 30, 2008 at 11:55:29 AM
sloping steel roof deck problem
Wed, Mar 5, 2008 at 5:55:12 PM
slope metal roof deck
Thu, Jul 21, 2011 at 9:40:39 AM
Combination Deck -Q-deck Floors
Thu, Sep 3, 2009 at 1:05:01 PM
Page generation time: 0.1296
