Forums >> Revit Building >> Technical Support >> Elevation Bubble not showing in Enlarged Plan
Thu, Oct 23, 2008 at 12:45:34 PM | Elevation Bubble not showing in Enlarged Plan
OleBanshee
I am currently working in Revit Architecture 2009 and having problems generating an interior elevations from an enlarged view.  I have created a callout of my area in the 1/8" plan and I switch to the 1/4" plan and select "View" the option to insert an elevation is grayed out.  Does anyone have any suggesttions to get this option back?  I have created a new new file from the base template and it works just fine.  I have compared the setting between my project and the base file in revit and all the settings seem to match.
Thu, Oct 23, 2008 at 1:21:22 PM | Elevation Bubble not showing in Enlarged Plan
You created a detail view - you can not place elevations in detail view.  When you make your callout, choose floor plan.
Thu, Oct 23, 2008 at 1:36:50 PM | Elevation Bubble not showing in Enlarged Plan
OleBanshee
That worked a lot better thanks for the help.
Detail Bubble Callout Options?
Thu, Aug 13, 2015 at 3:54:17 PM
Interior Elevation References
Thu, Jun 28, 2007 at 8:27:06 AM
Multi Segment Grid Line Bubble Issue
Wed, Dec 11, 2013 at 2:52:11 PM
Grid bubble in elevation
Sat, Oct 4, 2014 at 3:20:57 PM
Problem with Column bubble tag
Mon, Sep 14, 2009 at 3:46:07 PM
Page generation time: 1.5494
