Forums >> Revit Building >> Technical Support >> Door/ Window Editing (help)
Thu, Oct 23, 2008 at 9:20:28 AM | Door/ Window Editing (help)
gordi
i have my windows and doors set into my walls of my model and sat in position, but the cavity closers are not central to the cavity. All of my walls are 100mm block/ 100mm cavity/ 100mm block then ither a cedar boarded finish on timber framing or render finish! if i go into the element properties of my window or door and change it so the cavity closer is set X distance from external then in moves the closer into positon, BUT if i do this for say the rendered wall it would sit the closer in its correct position but then on the other walls with a thicker finish its not sat right!
IS there any way to make it so that the cavity closer constraist is set from the blockwork face of the wall insted of the very external face (finish)   sory if ive explained this crap!
cheers
Thu, Oct 23, 2008 at 1:25:45 PM | Door/ Window Editing (help)
? ? ?  Graphics would help explain
Maybe you should look at how you can do what you want from inside the door family.
Fri, Oct 24, 2008 at 3:15:37 AM | Door/ Window Editing (help)
gordi
what do you mean by ? ? ? Graphics?
 ive been into the door family editor and played around with creating new pararmeters which makes a new box for me in the doors element properties called **cavity closer offset from interal) this works but its only working on one side of the window. the other side the cavity closer is staying put..
Fri, Oct 24, 2008 at 7:28:44 AM | Door/ Window Editing (help)
What do you mean by cavity closure - do you mean wall closure?
Perhaps the H E L P will answer your questions.  Look at : family editor, wall closure planes and layer wrapping
Multi Panel Sliding door that is actually a Window Family
Fri, Feb 20, 2009 at 7:22:04 AM
Door and Window Scheduling - showing the door and window as an image.
Thu, Feb 11, 2016 at 7:50:51 AM
Revit 2014 Selection Window
Fri, Apr 11, 2014 at 7:49:24 AM
Storefront Door Editing
Fri, Jul 30, 2021 at 3:39:16 PM
Door and Window types
Thu, Nov 23, 2017 at 11:19:52 AM
Page generation time: 1.6816
