Forums >> Revit Building >> Technical Support >> Rendering Lines in Revit 2009
Wed, Oct 22, 2008 at 7:17:47 PM | Rendering Lines in Revit 2009
k2matty
I am building a rainscreen system (panelized) and would like to show the pattern layout of the panels in the rendering.  is it necessary to build each panel, or is there a way to render lines over one larger surface?
Thu, Oct 23, 2008 at 3:05:15 AM | Rendering Lines in Revit 2009
tim123
4 Stars: 19 Votes
You probably need to create a bump map fo the pattern and apply this to the curtain wall panel material.
Rendering in Revit 2009 [ 1 2 ]
Thu, Dec 31, 2009 at 10:41:31 AM
19
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:50 PM
Helping rendering in 2009
Sun, Apr 19, 2009 at 8:24:59 AM
Rendering function greyed out in Revit Arch 2009
Mon, Feb 16, 2009 at 4:53:18 AM
Rendering in 2009
Wed, Jun 11, 2008 at 3:18:08 PM
Page generation time: 4.8801
