27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Filled regions and viewports
22 Posts No Rating |
Small problem. There must be a work around.
On my main floor plan I created a filed region to hide some parking stalls in one corner. That way I can put the mezzanine plan on the same sheet with the two viewports overlapping. But the filled region on the main floor view also affects the mezzanine view where they overlap on the sheet layout.
In AutoCAD, I would just create a non-rectangular viewport but I can't do this in Revit. Or can I?
----------------------------------- Life is one of those things that people find hard to avoid. - Rowan Atkinson |
26 Posts No Rating |
Use your crop Regions
Use crop regions in what way?
Crop regions are only rectangular so I still can't remove a corner of the plan.
Hasn't anyone had this problem before???
possibly use a combination of fill regions and invisible lines to get what you desire.
if something better comes to be I will let you know.
Masking Regions and Filled Regions BEHIND 3D Objects |
Wed, Aug 1, 2012 at 8:10:27 AM
Filled Regions and families |
Sun, Mar 8, 2009 at 7:10:29 PM
Filled Regions on an elevation |
Wed, May 25, 2005 at 1:35:38 PM
Revit 2014 Filled Regions |
Fri, Jun 27, 2014 at 4:47:56 PM
11
Masking Regions and Filled Regions - Which Is In Front? |
Fri, Oct 28, 2011 at 2:26:55 PM
