8 Users Online (6 Members):
Forums >> Revit Building >> Tips & Tricks >> Similar Tags - Interior Elevation
After searching through the forums, I could not find the answer to a specific issue: How to create similar tags with regards to interior elevations that are identical, eg. toilet elevations? I found the answer and want to share that tip with whomever else may encounter this problem. To create similar interior elevation tags, go to the floor plan in which you want to create the tag. Next hit View > Elevation > reference other view > (select the view already created) > place it at the appropriate location and viola. You now have the same tag that can be placed on multiple sheets using the aforementioned process. This method also applies to sections and callouts. I hope this can save somebody some time.
Same as other callouts. From the view menu, click on elevation - choose interior elevation - check the reference other view on the options bar and find the correct view from the pull-down on the options bar.
98 Posts No Rating |
I discovered this one a couple weeks ago and was pleasantly surprised because it was something I didn't think Revit could do. It's nice to find those!
Interior Elevation Tags |
Mon, Jul 21, 2025 at 11:28:06 AM
Revit 2011 Multiple Interior Elevation References |
Wed, Oct 26, 2011 at 9:01:48 AM
2011 interior elevation tags |
Thu, Dec 23, 2010 at 11:44:57 AM
Scaling Interior Elevation Tags |
Fri, Mar 3, 2006 at 3:07:26 AM
Interior Elevation Tags in Detail Plan Views |
Tue, Nov 9, 2010 at 8:06:17 AM
