Forums >> Revit Structure >> Tips & Tricks >> CURVED WALL
Wed, Oct 22, 2008 at 12:20:00 AM | CURVED WALL
ylb121
How do you change the profile of a curved wall like a curved wall sloping down?
Wed, Oct 22, 2008 at 3:57:43 AM | CURVED WALL
4 Stars: 205 Votes
Hi, in a "Curved Wall" you CAN'T "Edit" the wall, so you can't change the profile/shape of that wall because it's in curve, what you can do it's "Create-in-Place" in the category "Wall" on wall with the shape you want, curve, slanted, in this way you can also insert doors, windows, sweeps and reveals with no problem...
Thu, Dec 4, 2008 at 1:52:14 AM | CURVED WALL
pauljackson84
1 Stars: 1 Votes
Hi,
I don't have any information about it.
But i think Typhon is right.
_________________________________________
Do you like to change your Contemporary Furniture.
Thu, Dec 4, 2008 at 4:34:34 AM | CURVED WALL
4 Stars: 205 Votes
Hi PAUL, you don't need any information, it's simple, create two walls, one straight and the other in arc, then, pick in the straight wall and you can Check in the menu bar the option "EDIT", but if you pick in the curved wall you DON'T get any button in the menu bar with "EDIT", so you CAN'T change the profile in Curved walls like in the straights walls and it has some logical "Elevation view/Lenght of Wall/Height of Top-Base of Wall" - SO many calculations to do.... maybe in the next version - WISHLIST
Edited on: Thu, Dec 4, 2008 at 9:28:36 AM
Thu, Dec 4, 2008 at 4:41:30 AM | CURVED WALL
Dafpfy
3.5 Stars: 11 Votes
Hi,
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Mon, Dec 8, 2008 at 3:12:58 PM | CURVED WALL
zanzibarbob
3 Stars: 1 Votes
What you can do is create a void in the shape you intend to cut from the wall.  Make sure it's wide enough to cover the curve then use cut geometry.  It's a workaround but it does work.
Thomas W. Hillis, LEED AP
Tue, Jan 20, 2009 at 6:25:34 PM | CURVED WALL
emgeeo
3.5 Stars: 7 Votes
As if those weren't enough options...
From an elevation view:
1.  Create a work plane at the desired slope.
2.  Pin the workplane - not necessary, but it will keep you from unknowingly deleting it.
3.  Select the curved wall.
4.  From the editing toolbar you now have the option of Attach and Detach for Top/Base.  Click Attach.
5.  Click the Reference Plane.
Curved wall and curved window
Tue, Jun 23, 2015 at 8:23:19 AM
Wainscoting in a curved wall
Wed, May 27, 2015 at 9:51:14 AM
couter top for a curved wall
Mon, Nov 22, 2010 at 5:02:47 PM
Complex Curved Walls - please help
Wed, Mar 25, 2009 at 5:26:10 PM
How to do a vertical reveal in a sweep in a curved wall?
Thu, Oct 22, 2009 at 2:04:26 PM
Page generation time: 3.6297
