Forums >> Revit Building >> Technical Support >> FLEXING & CONSTRAINING A CURVED EXTRUSION
Tue, Oct 21, 2008 at 3:51:09 PM | FLEXING & CONSTRAINING A CURVED EXTRUSION
dan5606
I have an extruded shape that resembles an upside-down U. I am trying to constrain the height to a particular dimension while flexing the width. The problem I have is that when I flex the width, the height changes. Revit assumes that the straight legs of the U should remain the same length as opposed to the radius shaping the curved part changing. Attached is my basic shape. Any help??
Tue, Oct 21, 2008 at 4:14:18 PM | FLEXING & CONSTRAINING A CURVED EXTRUSION
dan5606
WELL, I FEEL A LITTLE STOOPID. . . I FIGURED THIS ONE OUT SHORTLY AFTER I POSTED.
SHOW THE CENTER MARK OF THE CURVE. DIMENSION IT TO THE EXTENT OF THE SHAPE AND GIVE IT A LABEL. ASSIGN A FORMULA TO THAT PARAMETER TO SET THE RADIUS = WIDTH / 2.
ATTACHED IS MY NEW FILE THAT WORKS.
Wed, Oct 22, 2008 at 10:03:44 AM | FLEXING & CONSTRAINING A CURVED EXTRUSION
dan5606
NEW PROBLEM: Wall based upside-down U shape whose width is locked to ref planes which are locked a particular distance from each face (front edge and back edge) of the host wall, therefore, making the width adjustable to the host wall thickness.
The problem is that I still need the height to constrain to a particular dimension, say 3'. My previous fix depends on a length parameter named "width" to set the radius Cryingby way of formula) of the curved part of the U shape. Since the width of the U shape flexes with the wall thickness, I cannot create a label for the width because it overconstrains the shape. I can label a dimension from the centerline of the wall to the outer edge to use in the formula, however, once I try to change the wall thickness to see if it flexes, Revit informs constraints cannot be met.
It would be ideal if I could place a dimension that did nothing but provide value data that a formula could query. Revit doesn't allow this as far as I know. I'm stuck again with revit assuming the straight legs of the U shape are the static pieces of the shape.
Anyone have a work around or maybe a different approach??
Thanks,
Dan
Thu, Oct 23, 2008 at 2:31:53 AM | FLEXING & CONSTRAINING A CURVED EXTRUSION
teddynugget
teddynugget Avatar
3 Stars: 2 Votes
Hi dan.
Instead of making a parameter to control the radius of the arc, make a parameter for the height of the U, this way the U will stay at the fixed height and the legs will shorten or lenthen accordingly. You can add a dimension in sketch mode from the reference plane to the top of the arc.
Hope this helps
extrusion not flexing as i would expect
Thu, Aug 2, 2012 at 1:50:18 AM
roof by extrusion not working
Sat, Feb 26, 2011 at 1:41:39 PM
dental molding
Tue, Mar 13, 2007 at 9:50:04 AM
split face tool on curved extrusion
Thu, Nov 20, 2008 at 3:33:50 PM
13
Revit 2012 Roof by extrusion
Sat, Nov 19, 2011 at 4:49:20 AM
Page generation time: 0.3137
