Forums >> Revit Building >> Technical Support >> Calculating Distance
Tue, Oct 21, 2008 at 1:07:26 PM | Calculating Distance
tim1424
I am trying to calculate travel path distance.  In Autocad, you can create a polyline and reference its length in the properties dialogue box.  Is there a simple way to do a similar procedure thing in revit?
Tue, Oct 21, 2008 at 2:56:43 PM | Calculating Distance
KevinKernaghan
I believe under Drafting > Detail Lines you can draw a spline, that, when finished, will show it's complete length in its properties menu.  The spline option will be in the pull-down list to the right of the line type selection buttons.
That is, in Revit Architecture 2009.  Hopefully it is the same in other versions.
Tue, Oct 21, 2008 at 3:12:19 PM | Calculating Distance
tim1424
That'll work! Thanks!
Wed, Oct 22, 2008 at 5:54:01 AM | Calculating Distance
coreed
coreed Avatar
4 Stars: 16 Votes
also, if you just need to know what the distance is you can use the tape measure tool. turn on chain in the Options Bar and it will give you a Total Length read out in the Options Bar.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Nov 6, 2008 at 5:11:13 PM | Calculating Distance
CAPTAIN25
is there any way to have the distance read out as a "tag" on the drawing?  an associative dimension like this would be especially useful on an egress plan.
Fri, Nov 7, 2008 at 7:40:14 AM | Calculating Distance
Some people use a modified property line and a modified property line tag which only shows the segment distance.
Fri, Nov 7, 2008 at 7:54:23 AM | Calculating Distance
CAPTAIN25
can you expand a little on how to do this?
Fri, Nov 7, 2008 at 8:35:26 AM | Calculating Distance
Using a property line is not my preferred method but you can experiment with it and it is a tool that is already available.  Draw a property line on your floor plan and use the property line tag with distance to tag it.  You will see how it can work .... but ..... it does have problems.
Here are other solutions and discussions that may help you.
http://revitoped.blogspot.com/2007/01/egress-path.html
http://revitoped.blogspot.com/2007/01/egress-re-gress.html
http://forums.augi.com/showthread.php?t=38943&highlight=egress&page=3
There is an example egress plan using shared parameters in the "Documenting Your Projects Tutorials." The travel distance is calculated in a schedule for you.
pless help me (for Studies) Calculating quantities
Fri, May 6, 2016 at 1:29:25 AM
graphical cut back distance
Thu, Aug 19, 2010 at 11:14:35 PM
Calculating CFM on Return Ductwork problem
Mon, Dec 1, 2008 at 1:43:37 PM
Greyscaling elements at a distance?
Tue, Aug 16, 2011 at 7:30:52 PM
Calculating two Formulas on the same row in a Schedule
Fri, Dec 17, 2010 at 7:22:56 AM
Page generation time: 1.5109
