Forums >> Revit Building >> Technical Support >> Room Areas and Colour Schemes
Tue, Oct 21, 2008 at 3:44:48 AM | Room Areas and Colour Schemes
gordi
Is is possible to make room areas more accurate so i know that they arnt getting round up to the nearest m2, bedrooms on my building need to be exactly 12m2 and need to know if they definatly are!
also how do i create a custom colour scheme for my room! such as bedroom one colours wc,s another etc, but pick my own colours instead of using the revit standard ones it chooses for you?
cheers
Tue, Oct 21, 2008 at 3:51:29 AM | Room Areas and Colour Schemes
4 Stars: 205 Votes
Hi GORDI, the first problem you have, try in your "Units" when you choose meters put the "Decimal" in 2, also in the "Area", in this way when you are calculate the room area you know exactly the area of that room, about the second problem you can change the colors for that but i think you must go to HELP menu....
Edited on: Tue, Oct 21, 2008 at 4:34:26 AM
Colour Scheme (Areas) disappears when a plan region is added
Sun, Apr 19, 2015 at 11:27:47 AM
Areas Plan
Tue, May 14, 2013 at 12:02:12 PM
room areas, room separations
Mon, Jun 2, 2008 at 8:19:42 PM
Room & Area Colour Scheme
Mon, Nov 24, 2008 at 10:37:48 PM
rooma area of several room areas
Mon, Apr 19, 2010 at 1:45:30 PM
Page generation time: 1.0183
