20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Text On A Retail Sign
13 Posts No Rating |
Good Evening Everybody,
I put a retail sign at the front of my house. I put a text on it but I can't see it anymore after rendering. How is it possible to be able to keep it after rendering?
Thx a lot
Cypher
So you've applied a decal to a surface for the sign?
Decals will only show when rendered. If its not showing, check the decal properties to make sure the file location is correct or the image hasn't moved.
You cannot show decals in non-rendered views. If its an elevation you wish to show just import the image and place in the appropriate location. If 3D unfortunately there isn't really a way.
Or if 3d text see extruded text query below.
ADA Sign - Text not showing |
Tue, Sep 24, 2019 at 4:03:48 PM
Rendering Text |
Wed, Dec 10, 2008 at 4:47:01 PM
Parametric Exit Sign |
Mon, Apr 14, 2014 at 12:38:11 PM
13
Accidental Backwards Model Text |
Fri, Jun 5, 2020 at 11:59:29 PM
Retail Architecture |
Fri, Oct 21, 2005 at 3:30:54 PM
