Forums >> Revit Building >> Technical Support >> Wall type core boundaries
Mon, Oct 20, 2008 at 12:27:14 PM | Wall type core boundaries
chilenito
It has been several months (almos a year) since last time I used Revit. So I am working on a project we are doing on AutoCAD and it is in it's 75% CD. As a personal project I have decided to do it on Revit, specially because most of the decisions are already made and changes are minimal. This is good for practicing in Revit.
So my question is regarding setting up the exterior wall type, which is kinda unusual. It is a wall design for an area where there are woodpeckers. We want the woodpeckers to do their job in the facade, but we added an extra protection, so they do not get inside, or leave room for bats.
I can't just kite understand what is the purpose of the core boundary, and which elements should go inside or outside of it.
Please find a PDF of the wall type in CAD. I would appreciate anyone who can explain this to me, and what is the best method to layout the wall type.
Matias Santini
Mon, Oct 20, 2008 at 12:53:26 PM | Wall type core boundaries
Read your help using core and look at this topic "Applying a Function to a Layer of a Compound Structure".  This will help you determine what you want to put in the core grouping.
Tue, Oct 21, 2008 at 10:27:15 AM | Wall type core boundaries
chilenito
That was very interesting, how ever, it didn't respond my question. Which elements should go inside the core boundary, and which ones are tipically on the outside? why?
In the wall we are constructing there is an air space with 2x horizontal blocking @ 16" o.c.. Hoe can I have this blocking ar part of this layer, and shows correctly?
Thanks
Matias Santini
Tue, Oct 21, 2008 at 3:42:47 PM | Wall type core boundaries
I think you need to re-read the help.  It explains clearly what core means and the rules associated with that.  It is up to you what goes in the core based on how you want the walls to display.  This is not an architectural standards issue!
Custom wall type controlling display in plan view
Tue, Sep 8, 2009 at 1:20:58 AM
wall types, core boundries + dimensions
Tue, Feb 28, 2006 at 4:29:55 AM
Wall interior finishes - new wall type or a better way?
Tue, Mar 8, 2005 at 1:07:59 PM
Revit 2012 - Edit Room Boundaries
Tue, Jul 5, 2016 at 2:42:16 PM
11
hiding core elements in a wall section
Fri, Jun 23, 2006 at 1:07:58 PM
Page generation time: 2.9489
