Forums >> Revit Building >> Technical Support >> Creating an Outdoor Fireplace
Mon, Oct 20, 2008 at 11:18:32 AM | Creating an Outdoor Fireplace
JHectorne
RAC 2008 -- I am working on a remodel of a patio into a screened-in porch.  We are adding columns and using curtain walls to represent the screen panels.  On the new end of the porch, we are adding a fireplace which will sit between two columns (6'0" wide fp).  There in not going to be an offset on the outside of the porch; rather, the fireplace is going to extend into the porch.
Since, there is not a wall between these columns, how should I go about achieving this situation?  Should I make a new family with the Generic-floor based template or create an in-place family or hope to find what I'm looking for on the web?
Any ideas?  Thanks in advance.
Jim
"You've got to remember that we are just simple operators.  We are people of the web.  The common clay of the new millenium.  You know...Newbies."
Sat, Nov 1, 2008 at 7:59:38 AM | Creating an Outdoor Fireplace
tim123
4 Stars: 19 Votes
Any of these should work - it should be quite easy to model.  I attach one that I made which you can use if suitable or adjust if required.  There should be others on Revitcity.  If you only have one you can create an in-place family.
fireplace help
Mon, Dec 12, 2011 at 4:11:29 AM
fireplace
Thu, Mar 17, 2011 at 8:34:26 AM
Patio/outdoor furniture
Thu, Dec 13, 2012 at 3:46:53 AM
guys please help me i need a fireplace
Fri, Mar 22, 2019 at 2:12:57 PM
Fireplace doesn't export out into STL file
Sat, Jan 24, 2015 at 9:24:41 AM
Page generation time: 0.5553
