Forums >> Revit Building >> Technical Support >> Rotating CT tile patterns on floors
Mon, Oct 20, 2008 at 10:58:40 AM | Rotating CT tile patterns on floors
trhymans
I must be missing something.  I was trying to get a 12 x 12 ct tile pattern on a floor to rotate like the ceiling patterns on a 2x4 ceiling grid.  I set up a material w/ a 12 x 12 model cross hatch pattern but when I put it on a floor I cannot select the pattern like you can w/ a ceiling pattern.  Am I doing something wrong?
Mon, Oct 20, 2008 at 11:35:37 AM | Rotating CT tile patterns on floors
2d patters will not rotate.  It must be a model pattern.
Mon, Oct 20, 2008 at 11:52:57 AM | Rotating CT tile patterns on floors
trhymans
I did use the model pattern.  I then tried switching to the 2x2 ceiling pattern which does rotate on a ceiling but when I put that pattern on the floor it does not rotate.  It must be something w/ floors that makes it different.  Any other suggestions.
Mon, Oct 20, 2008 at 12:02:54 PM | Rotating CT tile patterns on floors
Nothing different about floors - I rotate my tile patterns all the time.  Not sure what you could be doing.  Are you using your tab key to select the pattern?
Mon, Oct 20, 2008 at 12:15:13 PM | Rotating CT tile patterns on floors
trhymans
That's it.  I don't seem to have to use the tab to select the ceiling patterns but on the floor patterns using the tab key does get me to the pattern.  Thanks
Tile Patterns, not line patterns
Fri, May 17, 2019 at 9:29:04 AM
Where do model patterns go?
Thu, Sep 24, 2015 at 9:37:41 PM
Three-Dimensional Tile Roof
Sat, May 30, 2015 at 10:43:29 PM
Hiding Floor Surface Patterns in Revit 2008
Wed, Jun 13, 2007 at 1:14:16 AM
Rotating Mulitple Floors at once
Mon, May 29, 2006 at 10:44:42 PM
Page generation time: 0.1370
