Forums >> Revit Building >> Technical Support >> can't see shadows on neighbours walls.
Mon, Oct 20, 2008 at 1:24:43 AM | can't see shadows on neighbours walls.
schuss
I have produced a shadow study on plan and 3d views, however I am struggling to show the effect of the proposed developments shadow on the neighbouring buildings.
I have set up elevations in the required direction however when I view the elevation of the neighbouring buildings it's own shadows appears and not that of my proposed develoment.  How do I show my proposed shadows on neighbouring buildings in elevation view?
I have figured out the shadows are visible in a camera view, but it is very distored.
Please help.
Tue, Aug 18, 2009 at 1:26:03 AM | can't see shadows on neighbours walls.
jacobischwartz
5 Stars: 2 Votes
bump. Anyone got a good solution for this?
Sun, Aug 23, 2009 at 10:30:58 PM | can't see shadows on neighbours walls.
schuss
I don't think it's doable unless you actually render it out, which is really slow, and doesn't look that great.  I've resorted to just showing a 3D image of the shadow effect on the neighbours walls.
Mon, Aug 24, 2009 at 1:13:36 PM | can't see shadows on neighbours walls.
tim123
4 Stars: 19 Votes
You can do it in an indirect way.  Create a 3D view and orient it to the direction of the relevant elevation.  The shadows will show even if the camera is in front of the objects casting the shadows.  It will be a true elevation although you won't be able to have it to scale, but you can 'eyeball' it and change the view size once it's on a sheet.
Mon, Aug 24, 2009 at 7:22:48 PM | can't see shadows on neighbours walls.
jacobischwartz
5 Stars: 2 Votes
@tim123, Do you mean a 3D perspective view, or a 3D orthogonal view? I thought you could only place 3D perspective views "in front of objects" - and then it wouldn't be a true elevation.
Tue, Aug 25, 2009 at 7:35:36 AM | can't see shadows on neighbours walls.
tim123
4 Stars: 19 Votes
Sorry, my error.  Orientating a perspective view will show the shadows, but is not a true elevation.  Orientating a 3D orthagonal view will create a true elevation, but will not show shadowss of objects behind.
Elevation Shadows
Sun, Jun 2, 2013 at 11:46:24 PM
Real shadows x Revits shadows
Mon, Aug 7, 2006 at 5:33:50 PM
Getting rid of shadows in Revit rendering?
Sun, Dec 3, 2017 at 2:06:46 AM
Shadows on floor plans
Sat, May 18, 2013 at 7:41:40 PM
Linked Models don't cast shadows???
Mon, Sep 27, 2010 at 8:48:07 PM
Page generation time: 0.6779
