Forums >> Revit Building >> Technical Support >> organic form
Fri, Oct 17, 2008 at 4:11:24 PM | organic form
shraddha
How do I model more organic forms?  I am trying to model this wall that is curvilinear in plan but, in elevation is not unifrom.  One side of the wall goes up a certain distance.  The other side angles up to another distance.  The angle is not uniform either.  I cannot figure out how to model this.  If I draw a curved wall I am unable to alter it's profile.  The sweep function doesn't work because things are shifting in too many directions.  Any ideas?  Help!
I believe I am using Revit 9 or 2008.  I cannot remember which one.
Fri, Oct 17, 2008 at 4:23:36 PM | organic form
4 Stars: 205 Votes
I think you are a bit Confused, "I believe I am using Revit 9 or 2008.  I cannot remember which one. " (see image attached and check what version are you work), " I am trying to model this wall that is curvilinear in plan but, in elevation is not unifrom.  One side of the wall goes up a certain distance.  The other side angles up to another distance.  The angle is not uniform either.  I cannot figure out how to model this.  If I draw a curved wall I am unable to alter it's profile.  The sweep function doesn't work because things are shifting in too many directions.  Any ideas?" can you put some screenshots about what are you trying to do???? (in plan, elevations, 3D views)
Tue, Oct 21, 2008 at 6:33:23 PM | organic form
shraddha
It was that I had one version of Revit at home, one at school, and one at work.  Unfortunately, they are all different versions.  Let's go with Revit 2009.
I have attached 3 images from a SketchUp model.
Tue, Oct 21, 2008 at 8:10:24 PM | organic form
vicozzio
Umm... I believe if you already have the Sketchup file, you can create that Sketchup file into Mass in Revit, and then you create building elements from that Mass... there's a tutorial to make Sketchup file into Mass in the tutorial...
What I remember is, first you create a new family for mass, you import the Sketchup file, and save it.
And then in Revit project, in massing tab in design bar, you select place mass.
After that, you use the Wall by face to create your organic wall...
Wed, Oct 22, 2008 at 3:49:35 AM | organic form
4 Stars: 205 Votes
Hi, it's more or less like Vicozzio says, in Revit go to "Massing" (in left menu) then "create a mass", give a Name - (by default is Mass1) then go to "File-Import" and choose that model, finish the sketch and then in "Massing" you have "Wall by Face"....
Wed, Oct 22, 2008 at 7:03:40 PM | organic form
shraddha
I'm sorry I guess I am not being clear.  I am trying to understand how I can model such a building without modeling it in SketchUp first.  I want to start and finish with Revit only. I had to do SketchUp only because I couldn't get Revit to work for me.  I'd like to understand how I can model irregular walls.  The simple line tools are insufficient if you cannot edit the profile of a curvilinear wall.
Thu, Oct 23, 2008 at 4:06:07 AM | organic form
4 Stars: 205 Votes
Well, sometimes (and if you see my Gallery) I prefer to use external programs like "Rhino" (in your case you do that with Sketchup) to do "Complicated" things because it's more "Faster" and "Simple", like you said "I had to do SketchUp only because I couldn't get Revit to work for me", but the way to do that kind of "curved / slanted wall" is "CREATE IN PLACE", go to "Moddeling-Create" choose the family type (wall) and use solids/voids to do that...
Edited on: Thu, Oct 23, 2008 at 11:38:13 AM
Thu, Oct 23, 2008 at 3:32:08 PM | organic form
4 Stars: 205 Votes
One more
Fri, Oct 24, 2008 at 3:11:56 AM | organic form
tim123
4 Stars: 19 Votes
You should be able to do what you want in Revit.  The way to approach this is to use the massing tools to create the shapes.  Try the swept blend tool and use voids to create the cut-outs.  Once you have the mass shape these can be converted to walls.
Organic form
Fri, Oct 14, 2005 at 4:58:08 AM
Organic form? / Simple form, but with a twist
Tue, Jun 9, 2015 at 6:41:27 AM
Difficult organic form - best ideas for modelling?
Thu, Mar 24, 2016 at 10:27:48 AM
Organic Ceiling Feature in Revit
Mon, Oct 28, 2013 at 11:14:12 AM
Organic Roof Form [mass in place], voids not cutting
Mon, Oct 24, 2016 at 3:06:35 PM
Page generation time: 1.4368
