Forums >> Revit Building >> Technical Support >> RELATING A FAMILIES OBJECTS TO TOP OF WALL
Fri, Oct 17, 2008 at 11:05:14 AM | RELATING A FAMILIES OBJECTS TO TOP OF WALL
dan5606
 I'm trying to make a parametric roof ladder that will read the top of wall.
 Does anyone know how to add a parameter to an object in a wall-based family relating to the "Unconnected Height" of the host wall?? "Unconnected Height" is an already existing instance parameter in each wall so I would think there is some way to access it.
It would be gravy if I could get this family to also read the height where a roof intersects with the wall but I could live without that as long as I could relate to top of wall.
 Thanks,
Dan
Fri, Oct 17, 2008 at 1:02:14 PM | RELATING A FAMILIES OBJECTS TO TOP OF WALL
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
I don't think it's possible. Revit doesn't like to relate parameters backward through families or family layers. I think the closest you'll be able to come is making the height alignab;e and locking it up to the top of the wall. That would make sizing each instance faster and if the wall changes height then the object will too. I haven't played with aligning vertically on wall-hosted families, but can't think of why it wouldn't work. Sorry I can't be of more help.
Curtain Wall queries
Tue, Mar 13, 2012 at 2:11:56 PM
Converting ArchiCAD objects into Revit families
Thu, Jan 17, 2013 at 9:43:29 AM
Sloped top of stone wall with wall cap on top
Tue, Mar 29, 2005 at 5:25:07 PM
How to make the top of the wall not horizontal?
Sun, Jan 23, 2011 at 7:17:41 AM
Wall Sweeps above Top of Wall - Revit Arch 2013
Tue, Dec 10, 2013 at 12:10:48 PM
Page generation time: 2.8618
