Forums >> Revit Systems >> Technical Support >> topo surface causing slow performance
Fri, Oct 17, 2008 at 10:01:32 AM | topo surface causing slow performance
AaronAddisonEmma
I am working on a project where I'm building a relativley large site by using the toposurface command.  As I add subregions to the toposurface however the program seems to grow increasingly slow.  By this I mean that the creating or editing of a subregion takes about 10 minuts to get into and out of sketch mode.  I am using a very high powered pentium 4 machine and cannot understand why regenerating would take so long.  I know that it is the large topo surface that  it is having a problem with but is there anything I can do to speed up the regeneration process?  Is splitting the surface into different pieces the only way to solve this problem?
Fri, Oct 17, 2008 at 10:21:01 AM | topo surface causing slow performance
4 Stars: 205 Votes
How large are your Project (in MB)? what caracteristics of your computer, Ram, O.S. (32 or 64 bits), Revit Version???
Edited on: Fri, Oct 17, 2008 at 10:27:32 AM
Fri, Oct 17, 2008 at 10:31:45 AM | topo surface causing slow performance
AaronAddisonEmma
The Sspecs. on my computer are attached and the file size of the revit drawing is 71 MB.
Fri, Oct 17, 2008 at 10:33:18 AM | topo surface causing slow performance
AaronAddisonEmma
revit 2009
Fri, Oct 17, 2008 at 10:46:33 AM | topo surface causing slow performance
4 Stars: 205 Votes
Well, you have a Pentium III Xeon with 3.2Gb of Ram working in XP SP2 and your file has 71MB, it start to be a BIG file, make a BACKUP and "Purge" that file what don't you need, also "Close Unused Windows" in the TOP "Windows" menu....
Fri, Oct 17, 2008 at 10:51:29 AM | topo surface causing slow performance
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
thats a decent machine, i wouldnt consider it high power but god enough for some terrain mapping. What is the precision of your surface? anything over a dozen acres I only use major contours, anything over 150 acres I break up into segments.
Fri, Oct 17, 2008 at 11:12:32 AM | topo surface causing slow performance
AaronAddisonEmma
The site is 233 acres and has a 500' change is elevation.  My topo lines are placed at intervals of 2'.    Is that too detailed?  An image is attached.
Fri, Oct 17, 2008 at 11:20:50 AM | topo surface causing slow performance
4 Stars: 205 Votes
Well, it's a BIG surface....
Fri, Oct 17, 2008 at 11:27:00 AM | topo surface causing slow performance
alabaster2513
3.5 Stars: 25 Votes
yeah thats pretty good size, i would simply the surface to a precison of 5' to 10' Other than that your best bet is to go 64bit OS with 64bit Revit.
Fri, Oct 17, 2008 at 2:58:23 PM | topo surface causing slow performance
4 Stars: 205 Votes
and put RAM on that... (i think i gonna to a Workstation RISC 2xQuadCore2 64GB RAM
Fri, Feb 25, 2011 at 2:58:09 PM | topo surface causing slow performance
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Reviving an old thread here.  I'm also finding huge slow-downs with editing the topo  ...we're modeling a HUGE chunk of town to show the extents of a university's land holdings, roughly 4 square miles of very low detail topo, with some regions of highly surveyed data..
currently it's one topo surface with many subregions, so I understand why it's slow, for sure.  I was considering splitting it to make edits easier, but now I'm not sure because of this problem:
I can't make new topo regions without experiencing the same ammount of delay.  I've turned off everything in VG except one 2-D cad drawing, and closed all but one siteplan view that's heavily cropped.  But still--at least two minutes to edit a NEW surface, 1 minute lag for each point placed or altered.  I cannot explain this delay, since it's disassociated from the bulk of the project.
File size is still just 30-40 megs.  I'm running win 7 64bit on a machine with 16 gigs ram and 8 cores, it chews through anything else.   Anyone have any experience withthis sort of scale, or this sort of slowdown?
Topographic surface linked vs. in model
Tue, Mar 19, 2013 at 6:15:37 PM
Topo Surface Edits Running EXTREMELY SLOW in 2010. Help :)
Mon, Jan 18, 2010 at 8:38:59 AM
Slow Model? – How to Increase Revit Performance
Thu, May 23, 2013 at 2:22:22 PM
Revit 2013 slow performance in citrix
Wed, Nov 5, 2014 at 11:03:13 AM
Surface pattern to Topo surface
Mon, Aug 19, 2013 at 10:50:10 PM
Page generation time: 0.9074
