19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> fill pattern and line style
50 Posts No Rating |
i have a filled region with concrete fill pattern, but the default fill is not dense enough
how do i edit this fill pattern? or can i? if not, how do i get a denser fill?
also how do i edit the fill region outline to show a broken (hidden) instead of the continuous (solid) line
Settings-->Fill Patterns-->Either model or drafting depending on your requirements then edit the existing concrete hatch pattern or add a new one, import the concrete hatch pattern from the revit.pat file, select the pattern then change the scale to get the desired density.
When drawing a filled region you can choose between all your line types for the boundary. Simply change the boundary to the appropriate linetype.
HTH.
Solid Drafting fill pattern |
Tue, Jun 23, 2015 at 1:35:01 PM
color scheme/fill pattern |
Mon, Jul 9, 2012 at 4:56:36 AM
Scaling fill pattern |
Thu, Nov 17, 2011 at 4:01:24 PM
How Do I Make My Fill Pattern Show In 3D View |
Tue, Jan 13, 2009 at 2:35:22 PM
Fill Pattern |
Mon, Jun 5, 2006 at 8:13:21 PM
