Forums >> Revit Building >> Technical Support >> Revit to 3D Max Texture map offset.
Thu, Oct 16, 2008 at 3:25:20 PM | Revit to 3D Max Texture map offset.
colemandesign
colemandesign Avatar
3 Stars: 6 Votes
When I import my revit file as an fbx into max I get slight offsets in some of my texture patterns. I.E. my ceiling grid lines no aligned with the lights or diffusers but at the correct scale.  I'm guessing there is somewhere i can adjust map origins without uvm mapping and chaing all the gizmo locations in max.  Any suggestions/ideas/conclusions?  Thanks!
P.S. Using both Revit 09 and Max Design 09
MAP TEXTURE IMAGES TO ELEVATIONS AND FLOOR PLANS
Mon, Mar 5, 2007 at 2:39:54 PM
Texture Map Problems
Sun, Feb 25, 2007 at 7:56:31 PM
Texture Map Gets Messed up after cut. (revit 2013)
Mon, Jul 1, 2013 at 9:10:10 AM
Got a problem with texture orienting from a imported revit model in 3DS MAX 2008
Tue, Mar 31, 2009 at 10:15:40 AM
REVIT and 3ds MAX
Mon, Apr 4, 2005 at 4:45:15 PM
Page generation time: 2.4523
