Forums >> General Discussion >> Revit Project Management >> Revision Clouds Turn off/ Tag to stay on
Thu, Oct 16, 2008 at 11:36:10 AM | Revision Clouds Turn off/ Tag to stay on
jcorva
If you have a revision cloud that has a TAG assoicated with the cloud, is there a way to turn off the cloud and leave the tag on?  There is a manager in the visiblity graphics under the annotation categories, but whenI turn off the Revision cloud, the tag also turns off.  Help Please.
Thu, Oct 16, 2008 at 11:56:00 AM | Revision Clouds Turn off/ Tag to stay on
jcorva
Never mind...i figured it out.
Thu, Oct 16, 2008 at 12:01:04 PM | Revision Clouds Turn off/ Tag to stay on
coreed
coreed Avatar
4 Stars: 16 Votes
if you are going to take the time to post. why not post the answer so every one can benefit. that is the purpose of this site.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Apr 8, 2010 at 5:36:46 PM | Revision Clouds Turn off/ Tag to stay on
rex916
The solution is to go to settings, revisions, this will bring up the setting for revisions and the way revisions are displayed in a drawing. From here you can tell it to show clouds and tags, or only clouds, or only tags per revisions. The only down side to this is say for example you have to revisions 1 and 2 on a sheet. Say you want to turn off the cloud for revision 1 but for revision 2 you want the cloud and tag to stay on. So you do the settings. Everything looks good on the first floor plan, but when you go up to the upper level revision 1 has the cloud turned off, but in reality you want the cloud and tag to show.
Any ideas on how to get revisions clouds and deltas to show up per sheet?
Thanks in advance
Revision Cloud
Tue, Dec 14, 2010 at 1:03:05 PM
Revision clouds - off on one sheet but not on other sheets - is this possible?
Fri, Mar 16, 2012 at 9:13:39 PM
Revision Cloud Goof!
Fri, Jan 20, 2012 at 8:39:14 AM
Revision Clouds
Tue, Dec 18, 2007 at 10:52:44 AM
Revision Clouds
Thu, Sep 11, 2008 at 2:19:42 PM
Page generation time: 1.1430
