Forums >> Revit Building >> Technical Support >> Mirror Project...
Thu, Oct 16, 2008 at 11:02:37 AM | Mirror Project...
mlohr
mlohr Avatar
  I am attempting to use the Mirror Project Tool on a large project (1.07M)...In the first attempt, I let Revit run for 2 hours before the operation shut down. The computer that I am running Revit on is a Dell with 3.25 GB of RAM and Intel Core 2 Quad Processor...I am looking for a way to channel/reconfigure the computer to put more power into the Mirroring operation...is this possible or do I need to find a super-computer to do this on?
Thu, Oct 16, 2008 at 1:38:19 PM | Mirror Project...
4 Stars: 205 Votes
And your Large project only has 1.07M? or 10.7M? or 107M??? because with that computer and the file only with 1.07M, I don't see any reason to Revit delay so much...
Edited on: Thu, Oct 16, 2008 at 1:57:48 PM
Thu, Oct 16, 2008 at 4:00:38 PM | Mirror Project...
mlohr
mlohr Avatar
Actually, not 1.07MB, it is 107MB (107,000KB?)
Thu, Oct 16, 2008 at 4:19:55 PM | Mirror Project...
4 Stars: 205 Votes
Well, a file with 107Mb (like i suspect) is a Large file and when you try to Mirror, "He" (revit) duplicate the information, it's like your file "grow" to double (214Mb), it's really a HUGE file to process, i have 8Gb of Ram and some times, when the file is large, "he" take a while to process, i don't know, i never had a file with that MB but you can try add more Ram (i don't know also, if you are using 64bits Revit and O.S. (Vista or XP) 64 bits)???
Thu, Oct 16, 2008 at 6:07:12 PM | Mirror Project...
mlohr
mlohr Avatar
Well, so far no luck mirroring this fil.  I have not tried to add more RAM yet and I think that will help but, I have tried to perform the operation on both 32bit - XP and 64bit - Vista without success.  So, I will keep trying some other options...actually, I am able to mirror the model by linking it into another file, but am not able to bring the sheets with all of the annotations/dimensions/tags etc. - I am trying to avoid having to re-do all of that work which we already did...Thanks for your response though - all the way from Portugal?  Cool!
Fri, Oct 17, 2008 at 3:30:14 AM | Mirror Project...
4 Stars: 205 Votes
Yeah, good luck with that....
Mirror Project - Revit Architecture 2013
Sat, Jan 25, 2014 at 5:41:31 AM
How do I mirror a project
Fri, Apr 14, 2006 at 8:41:58 AM
using the mirror comand [ 1 2 ]
Thu, Oct 15, 2009 at 9:13:36 AM
17
Callout Wont mirror, Need help !!!
Wed, Feb 19, 2014 at 8:49:10 PM
Revit Project Duplex
Sun, Feb 22, 2009 at 12:28:28 PM
Page generation time: 1.5298
