Forums >> Revit Structure >> Technical Support >> Will it Blend?
Wed, Oct 15, 2008 at 2:28:25 PM | Will it Blend?
mjstructures
mjstructures Avatar
I've an issue with my concrete columns looking like swiss cheese as they pass through slabs. How can I make them look like once piece?
Fri, Oct 17, 2008 at 6:31:33 AM | Will it Blend?
robinballew
robinballew Avatar
3 Stars: 4 Votes
As far as I can tell you used join geometry to combine the column and floors. What that did is remove the Column part. You can unjoin the geomerty but then the quantity of concrete will be off. What I have done in the past is cut a hole in the floor where the columns go. That way the columns look correct and the quantity of concrete is correct.
BallewDesigns.com
wall solid blend
Tue, Aug 18, 2009 at 3:56:25 PM
Void Blend not showing correct cut
Tue, May 5, 2009 at 11:21:00 PM
Massing Blend
Tue, Mar 20, 2007 at 11:58:48 AM
Swept Blend
Fri, Nov 28, 2008 at 4:39:26 PM
Please help me with swept blend!!
Mon, Jul 28, 2014 at 3:31:14 PM
Page generation time: 1.9982
