Forums >> Revit Building >> Technical Support >> Need to place a section arrow multiple times..................
Wed, Oct 15, 2008 at 10:47:57 AM | Need to place a section arrow multiple times..................
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
The same section detail occurs in a number of areas.  This is probably a stupid question but there has got to be a way to repeat the same section number and sheet symbol several times on a sheet, all using the same numbers.
Wed, Oct 15, 2008 at 11:03:14 AM | Need to place a section arrow multiple times..................
lmevans79
lmevans79 Avatar
There is a way to do this.  When you choose section, look at the options bar and check the box next to "reference other view".  This will allow you to use the drop down list and select the section you want to reference.  This works for elevations and callouts as well.
cut sections multiple places
Fri, Sep 2, 2005 at 10:36:21 AM
Segmented section cut
Wed, Oct 10, 2007 at 1:19:40 PM
Callout Detail Occurs @ Multiple Locations. Anyway to place detail bubbles...?
Thu, Jan 21, 2010 at 9:02:50 AM
Managing multiple copies of a building section in the same project
Fri, Oct 25, 2013 at 1:04:53 PM
Multiple referances to the same detail
Fri, Jan 20, 2006 at 1:50:53 PM
Page generation time: 1.5405
