Forums >> Revit Building >> Technical Support >> Dimension Text Problem
Wed, Oct 15, 2008 at 10:23:59 AM | Dimension Text Problem
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
I have inserted Dimension Text under string of dimensions.  When I go in to edit the witness line to pick up a missed dimension, all of the text is omitted when I add a new witness line.  I could understand that it would reset the dimension text in that bay but why omit all of it?  I then have to go back and add all of the dimension text and then find another dimension witness line that needs to be added.  It is a huge pain.  Anyone know a way around this problem other than don't do dimension text until you know there are no more witness line changes.
Fri, Nov 14, 2008 at 9:41:55 PM | Dimension Text Problem
balbrec3
4.5 Stars: 3 Votes
It may be because when you edit the witness line it wants to put the new dimension you added in the old text fashion and since the text you created was on the old one it offsets because every text on the witness line needs to be the same because its considered a family when its all connected.  Maybe try adding to the witness line and make sure the new piece you add has all the same settings as the old when you add it.  Hope this helps!
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
Overwriting Dimension with Text
Thu, Jan 11, 2007 at 11:13:56 AM
Multiline text below dimension
Tue, May 10, 2011 at 9:32:42 AM
Inserting text under dimension in string dimension
Thu, Apr 2, 2009 at 9:47:51 AM
scaling text and dimension according to the scale of view
Fri, Aug 29, 2008 at 10:26:28 AM
Page generation time: 2.7340
