Forums >> Revit Systems >> Technical Support >> Changing from Model to Symbolic Lines
Tue, Oct 14, 2008 at 3:52:38 PM | Changing from Model to Symbolic Lines
rwhite
To all,
Is there any quick way to convert model lines to symbolic lines?  I want to be able to highlight all the model lines and convert them to symbolic lines.  Please help!
Tue, Oct 14, 2008 at 4:25:27 PM | Changing from Model to Symbolic Lines
robinballew
robinballew Avatar
3 Stars: 4 Votes
NO..Sounds like a good macro..
BallewDesigns.com
Wed, Oct 15, 2008 at 6:10:21 AM | Changing from Model to Symbolic Lines
coreed
coreed Avatar
4 Stars: 16 Votes
there are some cut and paste work arounds. if you do a search you might be able to find s thread on the subject.
HTH
Edited on: Wed, Oct 15, 2008 at 6:11:13 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Oct 15, 2008 at 7:13:51 AM | Changing from Model to Symbolic Lines
I believe the work around is to export the view to cad with only the linework showing.  Delete all the lines, change all the lines in CAD to layer 0 or a layer you will recognize, then import the cad dwg and explode it.   Finally, delete the linetype with the same name as your import layer (0 ?) and all of your lines will be thin lines.
Wed, Oct 15, 2008 at 8:56:01 AM | Changing from Model to Symbolic Lines
coreed
coreed Avatar
4 Stars: 16 Votes
from Mr. Spot
"Make sure current view only is ticked when importing the dwg. This will effectively make them detail lines when the dwg is exploded."
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Oct 15, 2008 at 1:41:48 PM | Changing from Model to Symbolic Lines
coreed
coreed Avatar
4 Stars: 16 Votes
i got this from Steve Stafford site Revit OpEd
Model Lines to Detail Lines (use sketch based detail element)- Select Model Lines and Cut to Clipboard (CTRL + X)- Start a new Filled Region and paste the lines in anywhere- Select the lines and cut to clipboard again- Cancel making the Filled Region- Paste into view - they are now Detail Lines--
 Detail Lines to Model Lines (use a sketch based model element)- Select Detail Lines and Cut to Clipboard (CTRL + X)- Start a new Floor and paste the lines in anywhere- Select the lines and cut to clipboard again- Cancel making the floor- Paste into view - they are now Model LinesI'd been using the Roof by Footprint do this for awhile but the floor is "quicker" since you don't have to choose the roof method first 8-). Technically you could just edit an existing floor or filled region and paste and cut and quit sketch to accomplish the same thing.
Edited on: Thu, Oct 16, 2008 at 5:23:51 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Oct 15, 2008 at 2:20:04 PM | Changing from Model to Symbolic Lines
Thanks coreed ....
Fri, Mar 6, 2009 at 2:13:30 AM | Changing from Model to Symbolic Lines
rmaciel
Thanks, Coreed! A great time saver.
Ricardo
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
Symbolic lines
Tue, Dec 26, 2006 at 2:24:22 AM
Symbolic vs Model Lines
Tue, Feb 14, 2006 at 6:25:02 PM
symbolic lines
Thu, Jul 13, 2006 at 8:15:41 PM
Windows above the Cutplane and Symbolic Lines (Revit2010)
Wed, Jul 14, 2010 at 7:35:42 AM
Page generation time: 0.7963
