Forums >> Revit Building >> Technical Support >> Sheet Number Order
Tue, Oct 14, 2008 at 1:56:08 PM | Sheet Number Order
blackhawk
3.5 Stars: 3 Votes
Hello all,
Thanks in advance. I have searched the forums and I ask for help for a specific problem. I'm using Revit 09. When I attempt to order the sheets in the project browser by sorting sheet numbers ascending numerically, I encounter a problem where they are not in order numerically. This occurs when ordering sheets like A1.01, A1.02, A1.1, A1.2...for some reason Revit sorts them as A1.1 then A1.01, A1.2, A.02 and so on; but not A1.01, A1.02, A1.1, A1.2 etc. Revit doesn't recognize the 0 as a significant digit. I have attempted to create a new parameter using the browser organization tool to no avail. Please help, thanks.
Tue, Oct 14, 2008 at 2:22:49 PM | Sheet Number Order
Add a shared parameters to your sheets called sort-order and use that in your drawing index.  (You don't have to show the value in the index.)  You will have to add this value yourself.
You can then set the browser to sort using this as well.
Tue, Oct 14, 2008 at 4:12:00 PM | Sheet Number Order
blackhawk
3.5 Stars: 3 Votes
I was hoping to avoid doing that, as the help dialog gave a similar solution. It seems a bit unnecessary that Revit does not recognize 1.1 comes after 1.09...All the great things the program does automatically for us, and yet the simple computations are left for us to solve. HA.
Tue, Oct 14, 2008 at 4:22:30 PM | Sheet Number Order
blackhawk
3.5 Stars: 3 Votes
I appreciate the help. Thanks.
Tue, Oct 14, 2008 at 4:42:43 PM | Sheet Number Order
You don't seem to understand computers.   1.1 preceeds 1.09  but .... 1.10 follows 1.09...
so the answer is simple - keep your numbering to the same decimal places!
Wed, Oct 15, 2008 at 10:30:38 AM | Sheet Number Order
blackhawk
3.5 Stars: 3 Votes
HA! You are correct. Simple solution to a simple problem. Thanks for the help.
View List doesn't have parameter to show them in order of number on sheet?
Fri, Aug 26, 2016 at 2:48:10 PM
Ordered Sheet List with Consultants Sheet
Tue, Sep 8, 2015 at 1:27:22 PM
Numerate 'Sheet Number' parameter for match line family
Mon, Apr 28, 2014 at 10:17:51 AM
Automatic Sheet Counting Parameter
Mon, Sep 10, 2012 at 3:00:58 PM
Linking revision number to sheet number
Mon, Sep 20, 2010 at 1:50:30 PM
Page generation time: 2.3042
